Rock64 Login
Bug
Hi everyone!Nice to meet you.
I have a Rock64 v2.0, 20170713
I installed:
Armbian_5.59_Rock64_Debian_stretch_default_4.4.152_desktop.img using the Etcher flasher on microSD.
The first time I insert the flashed microSD card into the Rock64 i eventually get a login prompt asking for user.
I write in user: root and press enter.
There is now no response or it hangs for a long time and I don't get the password prompt. Sad
Then I press reset on the Rock64 board and after a while i do get some text on the screen, mainly hexadecimals and addresses cycling through, then the screen goes black. This goes on an infinite repeat loop.
I have a keyboard and mouse plugged in and wired Ethernet.
Does anyone have this or am I approaching this the wrong way? Confused
Many thanks,
luke
(10-01-2018, 10:24 PM)lpninja Wrote: Hi everyone!Nice to meet you.
I installed:
Many thanks,
luke
You can try out ayufan Bionic LXDE build, https://github.com/ayufan-rock64/linux-build/releases/, and check whether has similar issue.
You also can post your post at Armbian forum and somebody experience with Armbian build may able to provide better answer.
  MRAA Rock64 support jbize 2 2,460 07-09-2022, 04:40 AM
Last Post: igorp
  Rock64 with Debian netinst usb Bloris 6 8,909 12-03-2019, 12:37 PM
Last Post: madalin
  The differences between Rock64 and RockPro64 phamoanh 1 4,297 06-12-2019, 10:44 PM
Last Post: evilbunny
  Custom Kernel for ROCK64 mayst 2 4,966 01-07-2019, 08:04 AM
Last Post: mayst
  Rock64 suitable for headless TVHeadend install? elsmandino 3 6,365 06-26-2018, 11:37 AM
Last Post: Luke
  Will the Rock64 work as a mobile data storage device? Kennetht 1 3,100 03-29-2018, 10:07 AM
Last Post: xalius
  Laptop as a bridge for Rock64's internet connection dmitrymyadzelets 3 5,273 03-28-2018, 05:24 AM
Last Post: dmitrymyadzelets
  Rock64 OS eMMC boot ProfessionalDreamer 2 5,416 02-20-2018, 08:44 PM
Last Post: ProfessionalDreamer
  opencv on rock64 bendiro 4 7,108 02-07-2018, 05:08 AM
Last Post: xalius
  Kodi on Rock64 board cenguix 2 8,758 02-02-2018, 03:05 PM
Last Post: stuartiannaylor
