LAMP on Rock64
Sad
Hello everyone, I'm Matteo. A few days ago I'm trying to install a web environment on 4GB Rock64. I tried both with Debian and Ubuntu, but I had installation errors on MariaDB and PHP. Sometimes I've had kernel panics. Confused
What can I do?
What is the best distro to make a LAMP environment on Rock64?
thanks.
A kernel panic after a fresh install with automatic reboots isn't unusual... last time I saw that there was even a message indicating that it was being automatically fixed so it didn't happen again - so it may be something to do with self-tuning.
However, for a LAMP stack OS I would recommend either the xenial-minimal or xenial-containers rock64 builds - try both the "stable" (currently 0.5.15) and "testing" (currently  0.6.28) builds. I'm running the 0.6.25 container build on both SD and eMMC with no issues, and prefer the container build so things like MariaDB, apache, plex, etc, can run in docker containers... If you're still having trouble, maybe try the Armbian rock64 builds...
(03-31-2018, 03:45 AM)pfeerick Wrote: A kernel panic after a fresh install with automatic reboots isn't unusual... last time I saw that there was even a message indicating that it was being automatically fixed so it didn't happen again - so it may be something to do with self-tuning.
okay, thanks for your esplanation.
 I will try with xenial-minimal
I agree with using the Community Build Xenial Minimal Linux Kernel Armbian build.
http://wiki.pine64.org/index.php/ROCK64_..._0.4.16.5D
Good luck!
i made a lil tut on how i got my LAMP + Java/Tomcat webserver working on Debian Stretch minimal : https://forum.pine64.org/showthread.php?...7#pid36807
  irradium (based on crux linux) Rock64 riscv64, aarch64 mara 0 137 03-24-2024, 01:07 PM
  Rock64 v2 - did not work song / audio sqw200zu 2 1,334 03-14-2024, 03:09 AM
Last Post: dmitrymyadzelets
  Rock64 won't boot dstallmo 0 325 12-27-2023, 10:34 AM
Last Post: dstallmo
  HDMI doesn't work on rock64 Noung1991 1 600 11-21-2023, 08:33 AM
Last Post: as365n4
  Rock64 + Klipper + KlipperScreen Instructions godzilla62 0 600 10-22-2023, 01:52 AM
Last Post: godzilla62
  Rock64 Debian 11 (Bullseye) install problem jbize 15 8,283 10-12-2023, 05:14 PM
Last Post: tpaul
  slarm64 (unofficial slackware) Rock64 RK3328 (aarch64) mara 133 189,781 10-09-2023, 03:31 AM
  arch rock64 does not boot nemnob 0 584 07-09-2023, 03:28 AM
Last Post: nemnob
  RXDP from Win10 to Armbian on Rock64 Transportsicherung 0 641 05-27-2023, 06:11 AM
Last Post: Transportsicherung
  DietPi OS for ROCK64 MichaIng 41 33,049 12-07-2022, 08:22 PM
Last Post: luminosity7
