boot process for pine a64
Hi all,
I install "Xenial Mate" to sdcard, but I have not see bootloader file on sdcard, why the pine a64 can boot? I have used other board, it always have "bootloader" partition. But I saw that the pine a64 have not it with SD card, the means there are "bootloader" code on board? have anyone know the boot process for pine a64? Thanks!
The firmware bits (boot0/spl, ATF, u-boot) are in front of your actual partitions. Depending on if you use BSP or mainline u-boot/linux the locations differ a little. As for how A64 boots, check linux-sunxi wiki... http://linux-sunxi.org/BROM#A64 , http://linux-sunxi.org/Pine64#Boot_sequence
  Pine A64+ mainline mipi-dsi Learnincurve 3 6,434 01-12-2021, 07:36 AM
Last Post: Learnincurve
  DietPi OS for PINE A64 MichaIng 0 9,046 12-15-2020, 06:11 AM
Last Post: MichaIng
  Fedora 32/CentOS 8 Pine A64+ Images wideawake 2 5,360 10-02-2020, 11:38 AM
Last Post: mathiraj
  LibreELEC(KODI) for Pine A64 (+) pineadmin 6 15,411 05-02-2020, 10:29 AM
Last Post: aaronmarsh632
  Lakka-nightlies for Pine A64 (and H64) roel 11 18,847 04-23-2020, 12:55 AM
Last Post: roel
  Read DHT22 on Pine A64 ayufan 3 6,445 01-19-2020, 02:51 PM
Last Post: {-DesT-}
  Centos 7 for Pine A64 Luke 2 5,949 05-28-2019, 12:18 AM
Last Post: pineadmin
  NEMS Linux for Pine A64 (+) Luke 1 5,020 05-09-2019, 05:42 PM
  Pine Board using linux stuck during boot sequence ktaragorn 4 8,044 03-30-2019, 06:48 AM
Last Post: ktaragorn
  motionEyeOS (PINE A64(+)) pineadmin 4 11,750 11-09-2018, 03:25 AM
