Can't get past boot screen... (RESOLVED)
I can't get past the boot screen (the one that says PINE A64).  I've tried reflashing the SD card from Phoenix with both Android and Remix OS several times, and have waited 30+ minutes; but it does not seem to want to boot.  A LED close to the power supply turns red.  I'm using a power supply that is rated for 2A and a regular USB cord.  I don't have any peripherals connected to the Pine.  Both the power supply and cord work fine with one of my Raspberry Pis.
I have the tricked-out version, the A+ with 2 GB of RAM.
Any ideas on what's going on?
Do you have Ethernet/WiFi connected? If Yes - disconnect that! There is an issue with Remix and any form of connectivity.
Also - try changing the charger and USB cable!
You're not alone mate I managed to get the linux disto arch-pine64 to start so i know the board will work. it's the software that is stopping you, same as me. I've given up now.
What are you using a USB for ?
No networking or peripherals are connected. Arch almost works, but fails with a disk error. I never get a login prompt.
Arch booted for me but I couldn't use it as all the display settings where not changeable. For a laugh I'm going to try Raspbain on it
(03-31-2016, 08:03 AM)codetheweb Wrote: fails with a disk error.
Time to check your TF card then: http://wiki.pine64.org/index.php/Pine_A6...eit_Drives
A big word of advice- get genuine, (new prefered) micro sd cards, have nothing plugged in except for the power and HDMI output. No USB, no Wifi/Ethernet. Some had issues with any peripherals being connected on their first bootup. After the first time it fully loads, you can restart and add on any peripherals to it and it should work fine.
If I've helped you with something, please leave a rating for my responses.
The SD card I'm using was bought new from Best Buy... but I'll check it with the counterfeit tool just to make sure. As I've already said, there's nothing plugged in besides power and HDMI.
(03-31-2016, 08:57 AM)codetheweb Wrote: The SD card I'm using was bought new from Best Buy...
Counterfeit cards get into the supply chain pretty early somewhere in Asia so you get them from any retailer worldwide. Checking control samples doesn't work either since a retailer doesn't get a batch of 1000 counterfeit cards but maybe 50 out of 1000 are fake. Therefore always test directly after purchase. It's worth the time. And in case you use an USB card reader to later burn images on use this for the test also since sometimes it's the reader that corrupts data and the card itself is fine)
If you're on Windows I would prefer H2testw for the following reason: H2testw always shows actual transfer speeds while f3 only reports average speeds at the end. And it's pretty funny to watch SD cards or pen drives starting to throttle after a few minutes due to overheating.
I tested the card I was using, a SanDisk 64 GB, and the tool said it was bad.  I tried flashing a Samsung Evo 32 GB card I had laying around with Remix OS (after I had tested and the tool said it was okay), and now it's finally working!  Big Grin
Moral of the story: ALWAYS check your card.
Thanks to everyone for their help!
  Boot Ox64 after SPI Flash IC replacement kotnitro 1 1,139 05-26-2023, 02:19 AM
Last Post: kotnitro
  Star64 first boot (and success) bortzmeyer 1 1,577 05-24-2023, 02:45 AM
Last Post: draintroup
Exclamation Quartz64 model a wont boot AndyNZAUS 0 1,558 09-13-2022, 06:35 AM
Last Post: AndyNZAUS
  Maximum size of boot MicroSD for RockPro64 and Pinebook Pro commiecam 0 1,692 08-07-2022, 10:47 AM
Last Post: commiecam
  How to boot from SD card on pinebook pro linux123 3 6,057 12-02-2020, 10:29 AM
Last Post: linux123
Lightbulb Live boot with persistence? r00tn3rd 1 3,225 10-23-2020, 01:30 AM
Last Post: HotChocolate
  Occasional boot toiny 0 2,144 10-18-2020, 01:41 PM
Last Post: toiny
  SD Card boot - trying out OS Baconomics 1 4,365 06-19-2020, 06:58 AM
  7" LCD Touch Screen Panel IanJames 0 2,062 04-01-2020, 04:40 PM
Last Post: IanJames
  How to boot from the SD card and install to eMMC? ravanh 2 6,454 03-18-2020, 09:42 AM
