Pinebook wont boot from eMMC
So I installed Xenial image on my Pinebook. Ran updates, followed the directions here for increasing the speaker volume. Then I installed Android 7.1 on a microSD card. My pinebook was able to boot android when SD card was inserted and it booted Xenial when SD card was not present. However, after a couple of days of use, the pinebook only shows a blank screen when I try to boot from eMMC. It still boots Android from the MicroSD fine. I do not want to go through flashing another image to the eMMC. Is there anyway revive the Xenial on eMMC?
It is theoretically possible to boot the pinebook from SD ( gnu+linux build ) and then mount the eMMC (actually should already be mounted ) and do whatever "cleanup" or fix that might be required;  only, who knows what that might be;  the eMMC image seems to be borked, and only you know what happened.
it is much easier and safer to just reload the eMMC;  its easy and painless.
(08-05-2017, 09:56 PM)MarkHaysHarris777 Wrote: It is theoretically possible to boot the pinebook from SD ( gnu+linux build ) and then mount the eMMC (actually should already be mounted ) and do whatever "cleanup" or fix that might be required;  only, who knows what that might be;  the eMMC image seems to be borked, and only you know what happened.
Thanks. I guess, I will reload the eMMC then. May be try a different OS.
  Dead Pinebook - fix it or spare parts? oloturia 2 2,210 03-19-2023, 03:38 PM
Last Post: oloturia
  Broken bottom case of PineBook 14 Mick 1 920 02-22-2023, 05:49 AM
Last Post: Mick
  Original 14" Pinebook an Orphan? vdicarlo 2 1,259 01-05-2023, 10:42 AM
Last Post: jezek
  Booting with TOC0 u-boot -- should it work? dreadbit 0 716 11-24-2022, 10:19 AM
Last Post: dreadbit
  Pinebook Users are a nobody leperotero 13 12,593 09-06-2022, 09:29 PM
Last Post: zapper
  Does anybody repair pinebook pro laptops for a fee? Tsvi Bar-David 0 957 09-05-2022, 07:49 PM
Last Post: Tsvi Bar-David
  Pinebook with a broken screen and 2 eMMC's for sale. UK ONLY. frank-zappa 0 1,596 03-08-2022, 10:14 AM
Last Post: frank-zappa
  How to transfer customised OS from SDcard to emmc quixote 1 3,040 01-07-2022, 06:38 AM
Last Post: alanwake82
  Pinebook to Pinebook Pro-esque upgrade kit sebboh 5 7,499 08-18-2021, 11:01 PM
Last Post: Corkonian
  new pinebook help ron_burgundy 5 7,689 12-17-2020, 04:54 PM
Last Post: ron_burgundy
