GitLab CE?
I'm wondering if it might eventually be possible to have Pine64 with GitLab installed on it. They currently have a version for Raspbian Wheezy (https://about.gitlab.com/downloads/)
I think that having Gitlab running on pine64 will be possible and it is one of the things I will do with mine.
I will keep you posted for more details.
(02-24-2016, 02:13 AM)mane Wrote: I think that having Gitlab running on pine64 will be possible and it is one of the things I will do with mine.
Any updates for running GitLab on Pine64?
Just found this and after struggling with getting Apache set up for git (don't know much about Linux) I will test it tonight and report back.
Well I tried, but I just couldn't get it to run. I don't think it's a direct problem of GitLab and more the problem that you just can't run software without endless hacking of cryptic configuration files in crude text editors, while following out-of-date-tutorials. Being a novice in Linux this is not something I can get to work unfortunately. If someone else manages to get it running, it would be great to post what you did.
