Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1]
http://wiki.pine64.org/index.php/Main_Page#Android_6.0
It now has a "Android 6.0.1 Image (LCD and HDMI Video Output) Release 20170209 [ver 2.0.1]" (below the 6.0 ImageWink
I am trying the DD image for 32GB microSD Card.
Resolution looks somehow low to me, even after changing to 1080p, when I connect via VNC it also looks low. Not sure... Will try some more...
Looking forward to other user's experiences with this OS image!
I downloaded and tested this as I have the LCD. I was wondering if there was a way to get the power menu from the android 5.1 LCD build.
(02-16-2017, 12:35 PM)rookieone Wrote: http://wiki.pine64.org/index.php/Main_Page#Android_6.0
For the LCD build, the UI resolution of HDMI output need to mirror match with LCD screen resolution (1024 x 600).
(02-17-2017, 07:52 PM)priyamjani Wrote: I downloaded and tested this as I have the LCD. I was wondering if there was a way to get the power menu from the android 5.1 LCD build.
what is the "power menu"?
The option to turn off and reboot the tablet. I downloaded the apk from playstore. It works with this build. However, my pine64 does not boot the second time and only gives a black screen with the power led on. Is anyone one else having this issue?
Ha stupid me |-) Because it said 6.0.1 I thought let's download this one, but now I tried the "Android 6.0 Image (HDMI Video Output) Release 20170112 [ver 2.0.1]", which looks better resolution wise. Thanks!
I want to use this version just via HDMI to my TV. The resolution is terrible. Where do we edit to improve this?
tllim
First of all thanks for your efforts.
I tried the 6.0.1 image and it fits to SanDisk 16GB.
But unfortunately, I found the next issues:  Confused
- sometimes it can't boot on power on, so have to cycle the power twice, what is not good for many solutions based on it
- it shows issues with two partitions on the sdcard and suggests to format before use, but can't boot after that anymore (what could be the reason?)
- ES File Explorer (guess others too) works quite slow so that system often informs that "it isn't responding"
- Android keyboard (AOSP) can't be enabled for any languages, so there is English only
- Can't connect to local WiFi network  (endless obtaining IP address) though it works just fine under Android 5
d;-)
trying to install on pine64 2 gb on a 32 gb card. Etcher is stalling at 96% and rw speeds went down to half. Im not sure if that how it is supposed to be doing?
(03-21-2017, 08:24 PM)jauyzed Wrote: trying to install on pine64 2 gb on a 32 gb card. Etcher is stalling at 96% and rw speeds went down to half. Im not sure if that how it is supposed to be doing?
seems like microSD card issue.
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 388,741 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,729 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,848 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 6,997 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,068 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,623 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,344 07-15-2019, 08:29 PM
  Video freeze caused by overheating? wanthalf 4 7,264 07-14-2019, 08:26 AM
Last Post: hmuller
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 258,861 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,553 02-26-2019, 11:58 AM
Last Post: Twistedx
