New Pine 64 Screen Case from C4Labs
(10-31-2016, 03:49 PM)Dustin_C4Labs Wrote: We just released a case that integrates the Pine 64 and the Screen into a pretty compact package. Assembly is a bit complex, so I made a video (which is half edited with text--more to come on that). Assembly for Pine 64 Screen Case. If you're as excited about this as we are, you can order one at Pine 64 LCD Screen Case. As always, thank you for your support!
Hi Dustin. What is the dimension of the space for battery in the case? I cant get the LiPo from PINE store, so i need the right dimension before i get the lcd case. I already have the playbox from PINE but, not quite satisfied with it.
For PINE64 8000mAH LiPo spec, please refer to the spec, section 7.1, posted on PINE64 wiki: http://files.pine64.org/doc/datasheet/pi...000MAH.pdf
The dimension is 120mm x 70mm x 9mm
Photo C4 Labs Pine 64 Cases (Standard & LCD) Bluphire 95 164,213 11-02-2020, 08:43 PM
Last Post: Little_Johnny
Big Grin Super Mario case [NOW WITH UPDATED STL-FILE (April 27.)] Tarjei85 37 64,304 07-23-2020, 05:31 AM
Last Post: devendraraju
  Made a case for the Pine64 with Audio DAC installed kodachrome 1 3,965 11-12-2019, 04:52 AM
Last Post: xalius
  playbox case ribbon cable too short pinoosh 7 12,317 02-22-2019, 03:24 AM
Last Post: GaryFunk
  Clear case PIne 64 with VESA100 LIPO , RTC holder, and mini fan holes killor 6 11,538 08-05-2017, 07:15 AM
Last Post: killor
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 10,133 07-16-2017, 01:51 AM
Last Post: selina3
  A case with active cooling for 1Gb pine64 ishwest 5 10,050 06-28-2017, 04:05 AM
Last Post: ishwest
  Lego Case Kiryu 67 88,995 03-30-2017, 11:36 AM
Last Post: Luke
  Do Pine sell a tablet back cover? brucezepplin 4 7,811 12-20-2016, 08:24 AM
Last Post: Bluphire
  Pine 64 in a pine box :) sgjava 5 9,616 11-18-2016, 12:24 AM
Last Post: MarkHaysHarris777
