No sms receival on Arch Phosh Pinephone
I was fine up until a few days ago until I noticed that I wasn't receiving any sms messages even though I could download and upload using my sim card data.
I'm using the default phosh messaging applications and haven't really altered mobile connections in any way that could alter sms performance that I haven't already tried turning on/off in attempt of getting sms to work again.
Is this a problem with the messaging application, mmcli, lower level modem software, the physical modem, my service provider, or something else?
I can provide further information - this is all that seems immediately relevant after searching through other threads about similar issues.
(10-04-2022, 10:15 PM)pineuser0 Wrote: I was fine up until a few days ago until I noticed that I wasn't receiving any sms messages even though I could download and upload using my sim card data.
Check your modem to see if it is "Clogged". Every once in a while my modem gets backed up.
Here are the commands I use:
List all the messages in the modem (this will give you a number use it in place of the XX)
mmcli -m any --messaging-list-sms
Delete message in the modem
sudo mmcli -m any --messaging-delete-sms=XX
This used to restart the modem (you should not need this)
sudo systemctl restart eg25-manager.service
It's possible your modem is full (see this report) but mmcli commands won't do anything about it.  You'll need to use minicom or picocom to send AT+CPMS? to the modem at /dev/ttyUSB2. A response like
+CPMS: "ME",2,99,"MT",2,99,"MT",2,99
means there are 2 messages out of a maximum of 99 in the modem. If the modem is full, you can purge it with AT+CMGD=,2
If it's not full then the problem lies elsewhere.
  pinephone virtual keyboard aular 4 297 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 198 04-02-2024, 11:50 AM
  PinePhone - boot from microSD laserpyramid 5 469 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 107,912 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,713 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 571 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,253 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 471 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,630 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,834 12-04-2023, 02:14 AM
Last Post: Peter Gamma
