when i close my laptop lid the screen doesn't turn on? (debian bullseye based)
hello,
I am using dietpi, i messed around with it and i don't know why when i close the lid, i don't see anything! i don't see the backlight on too! so i'm not sure what happened, maybe i accidentally deleted a package or could be i have wayland
are you trying to close the lid and continue using the PBP through a dock/external monitor? If so, have you already checked the settings in your desktop environment for lid close behavior? I believe most default to putting the computer to sleep when the lid is closed, so it would need to be changed.
sorry late response. i was messing around with my pinebook and its just how it is i guess because i have sway wayland on it. i also dont have a dock for it yet.
unrelated, but would this dock work, it's a third party https://m.aliexpress.com/item/1005004533...4itemAdapt
Sorry, I didn't know nvme ssd would cause issue for this, I have one and it happened to not sleep for multiple times on a different sd card i had (i also use an sd card to boot, not emmc)
  Debian on Pinebook Pro u974615 8 438 03-22-2024, 03:57 PM
Last Post: u974615
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 203 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  install debian on pbp jsch 7 3,826 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,024 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 4,918 08-31-2023, 04:20 PM
Last Post: TRS-80
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 3,821 07-15-2023, 02:58 PM
Last Post: u974615
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 606 07-13-2023, 05:21 PM
Last Post: owaspfap
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,342 04-01-2023, 03:22 PM
Last Post: TRS-80
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 495 02-16-2023, 10:58 AM
Last Post: cowsay
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,200 12-09-2022, 12:43 PM
Last Post: as365n4
