Error trying to update Manjaro software
Hello. I receive the following error while trying to update software in Manjaro using Add/Remove Software:
Invalid or corrupted database (PGP signature)
Failed to synchronize databases
If anyone is able to advise I’d be grateful. I’m pretty inexperienced when it comes to Linux.
Hi there,
did u try updating outdated sig keys yet ... in terminal?
$sudo pacman-key --refresh-keys
$sudo pacman-key --populate archlinux manjaro
$sudo pacman -Syy
(08-18-2022, 08:09 AM)josmo Wrote: Hi there,
$sudo pacman -Syy
Thanks for responding! Refresh keys made no changes. Populate gave:
gpg: error reading key: No public key
-Syy output was:
error: GPGME error: No data
error: failed to synchronize all databases (invalid or corrupted database (PGP signature))
what about
sudo pacman -S manjaro-keyring manjaro-arm-keyring
 ezik
(08-31-2022, 12:58 PM)shulamy Wrote: what about
 ezik
Output:
error: GPGME error: no data
error: database ‘core’ is not valid (invalid or corrupted database (PGP signature))
error: database ‘extra’ is not valid (invalid or corrupted database (PGP signature))
error: database ‘community’ is not valid (invalid or corrupted database (PGP signature))
maybe bad mirror
ezik
  Manjaro Sway Theme Broken Eighty8 1 278 03-08-2024, 08:41 AM
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 316 03-01-2024, 06:46 PM
Last Post: Puckla
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 1,747 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 326 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,134 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,204 12-11-2023, 03:47 AM
Last Post: calinb
  Manjaro 20.04 not loading from SD (with Manjaro on eMMC) zaius 1 402 12-07-2023, 03:11 PM
  Error On Initial Setup HankLubowitz 2 530 11-21-2023, 05:36 PM
Last Post: igorp
  Manjaro ARM: enabling external monitors & fixing Broadcom WiFi after updating trifleneurotic 2 884 11-14-2023, 10:57 AM
Last Post: trifleneurotic
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,017 08-21-2023, 09:10 PM
Last Post: vanessadonald
