PP Keyboard question
Hi All,
The battery on my PP keyboard is recognized by Mobian as a power source in Settings --> Power on my PP (not pro edition); however, there five (5) power sources are listed, which are: unlabeled (Discharging), Main (0%), Extra (0%), Extra (0%), Extra (70%).
The button on the right side of the keyboard does not activate/deactivate charging status. Does not work when I do a double press or a long press.
Note: I can use the keyboard for typing.
I have never used the usb-c port on the PP to charge the PP while it was in the PP keyboard, so this isn't the cause. I wonder if a possible cause is a software update (I use mobian).
The PP keyboard battery did charge the PP battery when I first received it, but stopped recently, which is when I noticed it not working. I don't know when this issue first began because I only plug in the keyboard for testing progress of optimizing the operating system power consumption/compatibility with the PP keyboard. When the PP keyboard battery was working with PP, the PP keyboard battery increased the duration of use of the PP by about 50%, hoped it would be more.
Wondering if others have experienced similar issue.
Thanks in advance for any helpful information.
Stay well.
i noticed that different os's show battery indicator differently and also charging. my guess is, it's a bug in a software.
this console program gives some info.
$ upower -d
at least i noticed that if screen is on, then keyboard barely charges the pinephone.
Thanks zetabeta! That's helpful.
I have similar symptoms under mobian right now. When the PP is connected to the keyboard Main never shows more than 24% no matter how long it charges and even if the PP is turned off when charging. If I charge the PP when removed from the keyboard case it charges to 100% but only shows max 24% when it is put back in the keyboard case.
The case battery gives a reading between 94 and 97% but does not appear to charge the phone battery.
So, have the keyboard drivers been borked again, creating charging issues or are 1st batch keyboards starting to slowly die?
(07-09-2022, 09:04 AM)zetabeta Wrote: i noticed that different os's show battery indicator differently and also charging. my guess is, it's a bug in a software.
$ upower -d
Thanks. I will try running that later with my PP in the keyboard case.
  Pinephone keyboard needs pressure terarmot 4 1,254 11-15-2022, 04:29 PM
Last Post: _radv_
  keyboard case charging but not typing new2pinephone 1 189 11-15-2022, 03:56 PM
Last Post: _radv_
  selling 2x pinephone(pro) keyboard ragele 3 396 10-28-2022, 08:09 AM
Last Post: sacrednetwork
  PinePhone Keyboard on other phone/over USB Dakkaron 1 734 10-20-2022, 03:47 AM
Last Post: svenh
  PinePhone Keyboard Review, Documentation, Battery Tools and Custom Layouts Phalio 0 236 10-09-2022, 05:09 PM
Last Post: Phalio
  keyboard charging fault, chip "most likely damaged", how to be sure? korakin 1 294 10-06-2022, 02:50 AM
Last Post: korakin
  Keyboard drawing only 0.1A from charger qwazix 7 2,566 09-26-2022, 01:00 PM
Last Post: ClairelyClaire
  Faulty Pinephone add on Keyboard. Support Ticket: Id #12442 Kawayuppie 5 1,572 09-26-2022, 12:45 PM
  Pinephone (Pro) Keyboard Case for sale manubert 0 251 09-17-2022, 11:51 AM
Last Post: manubert
  Should I just never use the PP keyboard? Subsentient 9 1,757 09-08-2022, 12:53 AM
Last Post: drh
