Gembird USB Typ-C to HDMI has no HDMI output when connected to PinePhone PostmarkedOS
https://www.galaxus.ch/de/s1/product/gem...lsrc=aw.ds
The Gembrid USB to HDM adapter can also be found on Aliexpress (with a different name)
Martijn Braam wrote here in the forum about another usb-c apapter with VGA output:
«In theory any dock that uses usb-c displayport alt-mode for the video ports should work (which most are). The usb3.0 is a bit useless since the usb connection on the PinePhone is only 2.0. «
The Gembird USB Typ-C adapter shows a blue light to indicate that it receives power from the phone, but there is no HDMI signal when connected to a HDMI monitor. We plugged it into a PinePhone running PostmarketOS.
13.7.22 update:
- plug in an usb mouse is working
- removing usb mouse and replacing by usb keyboard is working
- mouse and keyboard together not working since to little adapters
- PinePhone charges when power over usb is provided
  Case for Pinephone totilele 13 6,995 04-11-2024, 11:48 AM
Last Post: gramonyl
  PinePhone Dock with laptop? Mikey1977Y2J 2 611 12-12-2023, 05:43 PM
Last Post: Mikey1977Y2J
  Update the PinePhone keyboard driver to support missing characters? Peter Gamma 8 8,091 10-22-2023, 08:43 PM
Last Post: Peter Gamma
  key repeat with pinephone keyboard rotwang 0 438 10-22-2023, 03:39 PM
Last Post: rotwang
  Pinephone with mini keyboard, trackpad and large power bank? Peter Gamma 0 503 10-21-2023, 07:50 AM
  Use the Linux Console with the PinePhone Keyboard mburns 2 992 10-20-2023, 04:11 PM
Last Post: mburns
  Mouse for the PinePhone? Peter Gamma 21 15,072 10-04-2023, 10:24 AM
  PinePhone Wallet Case Shane 5 4,952 09-17-2023, 12:52 PM
Last Post: J T
  KB: Using bus powered USB peripherals with the pinephone keyboard mounted docsunset 9 36,951 08-07-2023, 06:12 AM
Last Post: mikeb
  PinePhone flex breakout board with Grove female header jnpine 0 630 08-04-2023, 10:47 PM
Last Post: jnpine
