Keyboard support broken in Mobian?
On June the 6th I apt upgraded my PinePhone CE running Mobian Bookworm after 2 wks. It prompted me to reboot, and when I did the keyboard was no longer recognised, neither as a battery or as an input source, yet the keyboard battery continued to charge the phone itself.
I suspected this was an issue with the update and started investigating; from what I have gathered the keyboard battery is supported via module ip5xxx_power, and the keyboard itself via module kb151. None of these modules are present in my /lib/modules/5.15-sunxi64/kernel subtree, and I the modification date of kernel/drivers/power matches the 06/06 date.
I understand you can build these modules from source, but I would like to understand why they have disappeared in case this is an issue with Mobian and the maintainers need to be notified. I would appreciate if anyone with a working keyboard could locate these modules and confirm their location.
(06-07-2022, 02:20 AM)MacarioMorenoUK Wrote: On June the 6th I apt upgraded my PinePhone CE running Mobian Bookworm after 2 wks. It prompted me to reboot, and when I did the keyboard was no longer recognised, neither as a battery or as an input source, yet the keyboard battery continued to charge the phone itself.
I have the same issue. Apt updated on 06/06... I have power on and off but the k151 'bar' is missing in Mobian and no keyboard output. Apt update on 07/06 no change.
This has been reported as well in https://forum.pine64.org/showthread.php?tid=16756; basically the last release of the kernel (5.15.41-sunxi64)-1 shipped without kb151 or ip5xxx_power. As suggested by @zltpxqhp69o2 in the thread, an alternative is to use the 5.17 kernel in the unstable release branch:
sudo echo "deb http://repo.mobian-project.org/ unstable main non-free" >> /etc/apt/sources.list.d/mobian.list
sudo apt update
sudo apt install linux-image-5.17-sunxi64
This can then be reversed after the next release of the stable kernel; it is also worth keeping an eye at the mobian tracker: https://gitlab.com/mobian1/devices/sunxi...fee996ceb8 (as pointed out by @Brother Cadfael)
  pinephone keyboard + dock question tuxcall 7 2,725 02-05-2024, 03:17 PM
Last Post: wigan
  PinePhone Keyboard KJ6OHG 11 7,994 08-23-2023, 03:25 AM
Last Post: Kali
  Pinephone - broken power button rorus 10 9,166 05-18-2023, 09:11 AM
Last Post: kbm
  PinePhone keyboard layout with manjaro plasma daemonbsd 0 944 03-02-2023, 05:01 AM
Last Post: daemonbsd
  Pine phone USB keyboard connection CleanEnergyCleanEnvironment 1 1,117 02-20-2023, 12:14 AM
  PinePhone carrier support in Hungary notramo 7 2,628 12-14-2022, 12:18 PM
Last Post: notramo
  Mobian and Keyboard tim.senecal 17 11,568 08-10-2022, 02:25 PM
Last Post: MNtinkerer
  keyboard and usb-c oihantto64 17 10,204 07-16-2022, 02:02 AM
Last Post: bokomaru
  Can't find "-" on the keyboard gilwood 1 1,171 06-05-2022, 12:57 PM
Last Post: tecdroid
  adding some keys to pp keyboard case, pageup, pagedown, f11, f12, maybe others zetabeta 1 1,296 04-30-2022, 08:18 PM
Last Post: TRS-80
