F-Droid on a pinephone pro?
Can you install F-droid on a pinephone to get open source apps?
(05-14-2022, 03:51 PM)gilwood Wrote: Can you install F-droid on a pinephone to get open source apps?
F-Droid is an Android app, so that won't work natively. There are some approaches such as Waydroid and Anbox to run Android and its apps in containers, which will make some apps work to some degree. However it will be severely limited and especially on the Pro the hardware acceleration under Waydroid is currently not working due to a bug.
The Anbox woorking image found in the Mobian wiki comes with f-droid included, it was very unstable as of about 6 months ago, many apps wouldnt load and even the lineageOS updates barely worked.  It was a good proof of concept but not really useful, it also burned battery amp/hours at a rapid rate.  Even on a deskop machine anbox is not super stable though.
  bookworm vs trixie discussion for mobian in pinephone pro. zetabeta 9 1,467 02-20-2024, 12:40 PM
Last Post: mburns
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 43,586 02-13-2024, 02:54 PM
Last Post: fxc
  A Btrfs Image for Arch SXMO on the Pinephone Pro mburns 2 743 11-23-2023, 08:44 AM
Last Post: mburns
  Rhino Linux does not seem ready for the PinePhone Pro. mburns 2 881 11-23-2023, 08:39 AM
Last Post: mburns
  Megapixels on Mobian Bookworm on PinePhone Pro - Not Launching X0X0X0X0X0 1 634 11-07-2023, 09:44 AM
Last Post: mburns
  Seeking Contributors: Apache NuttX Real-Time Operating System for PinePhone Pro lupyuen 2 1,634 09-14-2023, 07:23 PM
Last Post: lupyuen
  What to do if your PinePhone Pro does not boot fxc 19 18,762 09-10-2023, 03:19 AM
Last Post: fxc
  Pinephone(pro) modem bug / shortcomings MadameMalady 2 2,384 06-19-2023, 03:40 PM
Last Post: MadameMalady
  Cannot update new PinePhone Pro bent 6 3,333 05-15-2023, 02:43 PM
Last Post: alaraajavamma
  Any tips to improve the audio quality of calls on the PinePhone Pro? tux_life 2 1,454 05-12-2023, 12:58 PM
