PBP Can't Boot Up
Dear Pine64 Community,
I really really love PBP. But, it's dead, unable to boot up.
I'm not sure what I did that caused PBP dead.
I have done all Wiki and steps to reset, bypass the power and reset again. None of this worked.
Please kindly advise. Thanks.
(04-17-2022, 09:23 PM)iscmob Wrote: Dear Pine64 Community,
So I assume it did boot before and you haven't changed the installed OS.
Did you boot it after a long period of inactivity?
Did you let it charge for a full day?
I have PBP for a year plus, working fine until I tried to change the software (fr Debian to others).
It had intermittent boot problem (ie sometimes it could boot up and sometimes it couldn't). Then I did the reset according to our Wiki page.
And the problem persisted. Then I remove the ribbon cable to the small MB and connect the Power Bridge Connector. This didn't work.
Thus, I had done all available steps on our Wiki to jump start PBP, still PBP cannot be revived.
Do you have a USB adapter for the eMMC?
Can you try to flash the original Debian image on the eMMC?
I do have a USB adapter and did reflash the eMMC. Still, it didn't solve the problem.
Is there a way to disassemble the whole laptop and check each component,  aseemble it back?
  uboot wont boot to SD card after upgrade jbradley419 7 757 01-19-2024, 02:29 PM
  Video Flashing/adjusting on boot and reboot jbradley419 0 274 01-16-2024, 09:17 AM
Last Post: jbradley419
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,170 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 654 12-13-2023, 08:17 PM
Last Post: trillobite
  Various freezes during boot & while running several Linux distros - hardware error? donuts 1 564 11-22-2023, 11:47 AM
Last Post: fxc
  Cannot boot to Kali SD card after uboot upgrade jbradley419 4 1,145 09-19-2023, 08:48 AM
Last Post: dachalife
  Does latest Tow-Boot install/work correctly for everyone? tophneal 4 1,821 08-03-2023, 03:30 PM
  Boot into NVME drive, no wifi, sound, buttons... PaulQ 0 787 07-13-2023, 01:50 PM
Last Post: PaulQ
  New Pinebook pro won’t boot Generaltuxenburg 4 1,909 06-14-2023, 07:20 AM
Tongue Yet another Pinebook Pro won't boot thread pinemouth 4 2,397 05-20-2023, 01:02 AM
Last Post: jackwilson
