Activating a SIM on Pinephone
Has anyone been able to activate a Tracfone or US Mobile SIM on the Pinephone and be able to make calls?  I have activated cards from both on my Pinephone and it seemed to go well but I can not make usable connections (calls usually do not connect at all) and the phone will not stay registered.
Do I have to get another SIM and activate it on a different phone?  That seems to be what most do.
I can't use any SIM in my Pinephone, I came here to also look for help.
It just doesn't detect the SIM card, it's as if it was not there.
I've tried with 3 SIM cards, all activated.
(04-17-2022, 05:23 PM)dxvargas Wrote: I can't use any SIM in my Pinephone, I came here to also look for help.
That sounds like defective hardware.
(04-17-2022, 02:24 PM)jhasler Wrote: Has anyone been able to activate a Tracfone or US Mobile SIM on the Pinephone and be able to make calls?  I have activated cards from both on my Pinephone and it seemed to go well but I can not make usable connections (calls usually do not connect at all) and the phone will not stay registered.
I got a SIM from Ting.  Checked compatibility: good.  Activated: successful.  Result: same behavior as with Tracfone and US Mobile.  Data somtimes works.  Calls sometimes complete but sound is always delayed and interrupted and the calls always terminate after varying lengths of time (usually just a few seconds but someimes several minutes).
Has anyone else successfully activated a Tracfone, US Mobile, or Ting SIM in the Pinephone and then had telephony work?
Typical ModemManager log entries:
<info>  [modem0] state changed (registered -> searching)
<warn>  [modem0] couldn't load operator code: Current operator MCC/MNC is still unknown
<warn>  [modem0] couldn't load operator name: Current operator id is still unknown
<info>  [modem0] 3GPP registration state changed (searching -> idle)
<info>  [modem0] state changed (searching -> enabled)
<info>  [modem0] 3GPP registration state changed (idle -> unknown)
<info>  [modem0] 3GPP registration state changed (unknown -> idle)
<info>  [modem0] 3GPP registration state changed (idle -> registering)
<info>  [modem0] 3GPP registration state changed (registering -> home)
<info>  [modem0] state changed (enabled -> registered)
I successfully used a Tracfone sim (ATT network) with a PP. Started using it a couple of years ago. Just moved it from my prior phone to the PP. Was problematic until upgraded to Biktorgi's firmware. After that it worked flawlessly, until today. Have a cell network registration issue that I have just started investigating.
(06-18-2022, 10:54 AM)joe_w Wrote: I successfully used a Tracfone sim (ATT network) with a PP.  Started using it a couple of years ago.  Just moved it from my prior phone to the PP.  Was problematic until upgraded to Biktorgi's firmware.  After that it worked flawlessly, until today.  Have a cell network registration issue that I have just started investigating.
Issue turned out to be tracfone's att mvno.  bought their bring your own phone sim kit ($1.00) and installed a t-mobile mvno sim card.  pinephone is now working normally.
  PinePhone - boot from microSD laserpyramid 6 553 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 346 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 230 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,955 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,788 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 602 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,351 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 494 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,681 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,946 12-04-2023, 02:14 AM
Last Post: Peter Gamma
