Pine Wifi Module
Has anyone gotten the Wifi module working?
https://pine64.com/product/rockpro64-1x1...-0-module/
"Based on Azurewave AW-CM256SM Combo Module and made specifically for the ROCKPro64 SBC"
I'm not a linux expert, and have never made packages to install drivers before so any kind of tutorial would be great.
(03-30-2022, 10:16 AM)williamdieter Wrote: Has anyone gotten the Wifi module working?
I've packaged wifi drivers in the past by finding a similar driver and updating the source code/config and then building it for debian
I am using a dual boot system with Armbian and Devuan (a Debian fork).
Armbian supports rockpro64 wifi/bt module, Devuan (like Debian) does not.
A quick and dirty solution is to copy all Broadcom drivers from Armbian to Devuan/Debian (keeping the same path):
/ lib / firmware / brcm / *
/ usr / lib / firmware / rkwifi / *
The file drivers for rockpro64 are named *43456* for wifi and *4345C5* for bluetooth but I had some strange problems using only these files, while copying the entire contents of the two folders the system works better (these are considerations that I made without having still had time to investigate).
Bye.
https://github.com/armbian/firmware
  AW-CM256SM wifi card mtek 4 2,316 10-30-2023, 12:00 PM
Last Post: diederik
  U.FL plug on the Wifi/BT module? domih 8 12,724 10-17-2022, 04:43 AM
Last Post: callegar
  SCAM from Pine fieni 9 7,934 12-14-2021, 02:22 AM
Last Post: fieni
  To Wifi or To Bluetooth, That is the Question WarpLover 0 1,568 07-06-2021, 08:45 PM
Last Post: WarpLover
  RP64 TV box case with wifi Wizzard 2 3,282 03-10-2021, 12:23 AM
Last Post: Wizzard
  Suggestion: PineAIO - 32" screens with upgradable Pine boards inside - mitcoes 0 1,523 03-01-2021, 03:21 AM
Last Post: mitcoes
  Pine A64 assembly Spxrgie 0 1,567 01-29-2021, 09:17 AM
Last Post: Spxrgie
  OpenWRT + Intel I350-T4 + 1x1 Dual Band WIFI pi64 0 2,018 11-17-2020, 04:25 AM
Last Post: pi64
  Pine LCD on Rock64Pro DStanman 11 15,394 11-05-2020, 09:10 PM
Last Post: anotherandrew
  new WIFI/BT module not working with android 8.1 Firesped 0 2,011 05-12-2020, 10:33 PM
Last Post: Firesped
