Upgrading a 2020 Community Edition Pinephone?
Question
I bought a Community Edition Pinephone back in 2020 and would like to upgrade it to the 3GB RAM, 128 GB eMMC board. Is that practical/possible to do myself, or would I do better to buy a new, complete Pinephone with these specifications instead? I enjoy simple DIY computing/electronics projects.
Thanks in advance.  Big Grin
For byte-sized tech and software tips check out my Danimations Digital Media tips channel on Youtube Big Grin
(03-02-2022, 09:39 PM)danimations Wrote: I bought a Community Edition Pinephone back in 2020 and would like to upgrade it to the 3GB RAM, 128 GB eMMC board. Is that practical/possible to do myself, or would I do better to buy a new, complete Pinephone with these specifications instead? I enjoy simple DIY computing/electronics projects.
128 GB emmc, did you mean 32GB? https://pine64.com/product/pinephone-com...mainboard/
you didn't tell what hardware revision you have.
my guess is you are better off with new one. however, because no soldering is not involved, it's somewhat easy to replace mainboard. you need correct screwdriver and remember esd electricity.
when i soldered mainboard 1.2a into 1.2b . just removing tiny resistor was super difficult.
Oops,yes, I meant the 3GB/32GB mainboard. I must have misread the eMMC capacity at some stage. I thought 128GB seemed excessive.
Where do I check which hardware revision I have? Is it written on the device somewhere, or can I query it using Terminal?
There is no soldering, but it is quite fiddly to my understanding, with tiny little wires and delicate ribbons, etc.
Luckily, there are a few videos on ThemTube about differing levels of PinePhone disassembly, which you could watch and form your own opinion, as you know your own abilities best.
Cheers,
TRS-80
Protocols, not Platforms
(03-03-2022, 08:16 AM)danimations Wrote: Oops,yes, I meant the 3GB/32GB mainboard. I must have misread the eMMC capacity at some stage. I thought 128GB seemed excessive.
probably best place is to look at https://wiki.pine64.org/wiki/PinePhone#H..._revisions
there is one command "lshw", but could be innacurate. shows 1.2 for me even it's 1.2b (i have two pinephones).
no clear markings on mainboard either.
Given timing and description, mine is most likely Rev 1.2b. BTW, the "lshw" command wasn't recognised by Terminal.
  my pinephone melted norayr 6 726 04-04-2024, 07:22 PM
  Pinephone refusing to charge while suspended tiol 1 1,029 04-02-2024, 10:54 AM
Last Post: joH_N_Doe64
  various tricks to open the pinephone shengchieh 2 646 03-23-2024, 09:27 AM
Last Post: Ferriah
  pinephone can provide more than 500mA to a usb-c displayport device? unrznbl 2 264 03-21-2024, 08:52 AM
Last Post: unrznbl
  pinephone keyboard + dock question tuxcall 7 2,655 02-05-2024, 03:17 PM
Last Post: wigan
  Unsatisfactory GPS reception on PinePhone? LinAdmin2 53 54,995 12-17-2023, 11:42 AM
Last Post: robin.com.au
  PinePhone Pro not booting (Cap error!, pctl timeout) jealda 2 1,331 11-16-2023, 05:03 AM
Last Post: DrYak
  Pinephone frame damages Uturn 2 915 10-23-2023, 02:49 AM
Last Post: Uturn
  PinePhone Keyboard KJ6OHG 11 7,902 08-23-2023, 03:25 AM
Last Post: Kali
  PinePhone constantly vibrating and won't take charge ImmyChan 5 5,352 07-23-2023, 03:49 PM
Last Post: kb-zealot
