Can the kernel be bumped to a version that supports the driver for usb wifi dongle 8192eu?
Driver usb wifi dongle 8192eu
I just looked and my kernel has a rtl8192cu driver...
did you run pine64_update_kernel.sh ? My kernel version is: ubuntu@pine64:/$ uname -a Linux pine64 3.10.102-0-pine64-longsleep #7 SMP PREEMPT Fri Jun 17 21:30:48 CEST 2016 aarch64 aarch64 aarch64 GNU/Linux ubuntu@pine64:/$ lsmod Module Size Used by rtl8192cu 66504 0 rtlwifi 60032 1 rtl8192cu rtl8192c_common 40280 1 rtl8192cu mac80211 370652 2 rtlwifi,rtl8192cu
Come have a chat in the Pine IRC channel >>
06-29-2016, 04:00 PM
Yes, I ran the update scripts and have the same driver. This device really needs the eu, not the cu, driver. Not sure in which exact kernel version this got supported a while back, but that is the only way to solve this in a robust way.
06-30-2016, 03:55 AM
I have reported it at https://www.pine64.pro/bug-reports-3-10-65-bsp/ under the title "Support USB WiFi dongle driver 8192eu" but could not link to it directly. Perhaps someone else can post a direct link to it.
06-30-2016, 10:11 AM
Did you try 'sudo apt-get update' then 'sudo apt-get install linux-firmware' ? That worked for me, and I've had 5 different usb wifi adapters work seamlessly on my Pine64 with Debian Mate.
07-05-2016, 06:08 PM
(06-30-2016, 10:11 AM)CaptainZalo Wrote: Did you try 'sudo apt-get update' then 'sudo apt-get install linux-firmware' ? That worked for me, and I've had 5 different usb wifi adapters work seamlessly on my Pine64 with Debian Mate. Could you possibly list them? I'm having problem with my wifi adapter and I would consider buying new one if there is one inexpensive that works for sure.
07-05-2016, 07:46 PM
(This post was last modified: 07-05-2016, 07:50 PM by lenny.raposo-pine64.pro.)
if this is debian the realtek firmware should be already there if it is ubuntu firmware-linux-nonfree firmware-realtek are more than likely your best bet
try apt-cache search firmware to search for all firmware packages (realtek should be listed there as well as linux-nonfree)
If you like my work be sure to check out my site or wish to donate to the cause
Cheers ![]()
07-14-2016, 06:03 PM
(This post was last modified: 07-17-2016, 06:03 PM by vinodmenon80.)
(07-05-2016, 06:08 PM)Beta_Ravener Wrote:(06-30-2016, 10:11 AM)CaptainZalo Wrote: Did you try 'sudo apt-get update' then 'sudo apt-get install linux-firmware' ? That worked for me, and I've had 5 different usb wifi adapters work seamlessly on my Pine64 with Debian Mate. Hi CaptainZalo, Please list the 5 models of usb wifi adapters that work for you on the Pine64. I'm pretty sure that this would benefit others as well. Thanks ![]() btw I have a Prolink usb wifi dongle that should be compatible. I've yet to test it out since I need to obtain a switch that I can solder onto the board. When that's done, I will install debian and test out the dongle. Its supposedly linux & android compatible.
07-16-2016, 04:03 PM
(This post was last modified: 07-16-2016, 11:34 PM by CaptainZalo.)
(07-14-2016, 06:03 PM)vinodmenon80 Wrote:(07-05-2016, 06:08 PM)Beta_Ravener Wrote:(06-30-2016, 10:11 AM)CaptainZalo Wrote: Did you try 'sudo apt-get update' then 'sudo apt-get install linux-firmware' ? That worked for me, and I've had 5 different usb wifi adapters work seamlessly on my Pine64 with Debian Mate. Sorry. I haven't subscribed to this thread, so I didn't see this post until vinod made me aware of it. Here is what I wrote him in a PM: I am currently on summer vacation and won't get back home until last half of august. I can remember this: 1: NetGear N300 Mini USB, unknown chipse. Realtek I think. 2: WiPi old adapter with BCM43143 chipset. 3: New WiPi adapter (red text and slanted edge) with Ralink 5370 chipset. 4: A NoName adapter with RealTek RTL8192 chipset. 5: Last one is a nano style USB linksys adapter, but I can't remember name or chipset. All of these work in ubuntu and debian images after doing 'sudo apt-get install linux-firmware' |
WiFi dongle MediaTek mt7601u | Beta_Ravener | 13 | 16,303 |
11-28-2017, 11:58 AM Last Post: Aadhyatm |
Pre-Configure Wifi on Pine64 without Keyboard/mouse | bortek | 4 | 5,579 |
01-23-2017, 02:04 PM Last Post: bortek |
Mali driver for fbdev/kms & wayland? | jacklau | 1 | 3,079 |
10-21-2016, 11:19 AM Last Post: CaptainZalo |
Pine64+Ubuntu+Tvheadend+DVBT Dongle | Shai | 3 | 4,791 |
10-03-2016, 04:23 AM Last Post: Shai |
WiFi PineA64 Pineapple | Ghelorn | 2 | 4,893 |
09-25-2016, 03:05 AM Last Post: Ghelorn |
Mali Driver Update | FR0$T | 2 | 3,634 |
07-20-2016, 10:44 AM Last Post: nagmier |
third party wifi | rahlquist | 3 | 3,537 |
04-27-2016, 02:39 PM Last Post: baryluk |
