jumpdrive software might be faulty (or my pinephone hardware)
this is quite preliminary view and when i get more information, i clarify what's going on. still it's headzup issue for some. i have pinephone hardware 1.2a.
i noticed that using jumdrive software, both 0.7 and 0.8, computer only saw 6GB intenal storage instead of 32GB. using telnet, then size was correct. this meant that flashing was not succesful.
https://github.com/dreemurrs-embedded/Ju...e/releases
i ended up installing o.s. to the memory card and after that i installed to the internal memory.
serious disclaimer, my pinephone could be faulty by hardware because i have some issues with gps as well.
(07-19-2021, 06:55 AM)zetabeta Wrote: jumpdrive software might be faulty (or my pinephone hardware)
probably false alarm
seems to be that i have problem with my computer, in this case debian. for some reason 32GiB usb memories function as 6.79GiB in size. happened also with other usb memory. actually usb adapter for sd card.
it could also be the ISO, double check it to make sure it's not a 6GiB iSO
old fashion reboot and computer showed sizes correctly. so, i assume something was messy with linux kernel when attaching and detaching usb mems.
i don't have optical drive (actually i have usb based optical drive but rarely used). if bug repeats, i check is it optimal image or something else weird.
side note: i use "lsblk" , "fdisk -l" and others to show sizes. in this case i meant whole disk/mem size and not partition sizes.
  PinePhone - boot from microSD laserpyramid 6 534 04-22-2024, 02:22 AM
Last Post: bongosunny
  pinephone virtual keyboard aular 4 337 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 227 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 108,846 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,773 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 597 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,332 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 489 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,671 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,932 12-04-2023, 02:14 AM
Last Post: Peter Gamma
