[Panfrost] now support stable OpenGL ES 3.1
For those who missed the info : https://www.phoronix.com/scan.php?page=n...nGL-ES-3.1
Quote:OpenGL ES 3.1 most notably adds compute shaders, indirect draw commands, and other additions. Meanwhile OpenGL ES 3.2 is the latest upstream spec for this mobile-focused graphics API. Arm's Midgard 2nd Gen taps out at OpenGL ES 3.1 while Midgard 3rd/4th Gen and Bifrost are ultimately capable of OpenGL ES 3.2 once this open-source driver support has been wired up.
Exclamation 'failed to open panfrost' after system update using archarm Puckla 1 316 03-01-2024, 06:46 PM
Last Post: Puckla
  Manjaro [ARM Stable Update] 2021-07-23 issues Bocanila 1 2,016 08-21-2023, 09:10 PM
Last Post: vanessadonald
Brick Are there any usable/ stable distros for PBP? pineymousepad 16 6,632 05-24-2023, 10:06 AM
Last Post: Vinay
  Armbian is [edit: no longer] dropping support for Pinebook Pro TRS-80 4 4,110 12-23-2022, 12:01 AM
Last Post: TRS-80
  Armbian VPU decoding support coming soon LivingLinux 0 799 11-13-2022, 02:32 PM
Last Post: LivingLinux
  Manjaro PBP stable update 2022-06-19 bricked wpeckham 2 1,649 06-30-2022, 10:03 PM
Last Post: wangyukunshan
  Kernel 5.17 will improve VP9 support? jiyong 1 2,119 01-16-2022, 08:26 PM
Last Post: xmixahlx
  Ungoogled Chromium on a Pinebook Pro won't run - OpenGL errors? pinemouth 2 2,733 12-09-2021, 02:23 PM
Last Post: pinemouth
  Debian GPU Support Atton 5 5,672 12-02-2021, 05:37 PM
Last Post: cobratbq
  Solution for issue with 'panfrost' module not initializing due to missing dependency cobratbq 0 1,577 12-02-2021, 05:26 PM
Last Post: cobratbq
