Debian GPU Support
I must ask if there a version of debian for the pinebook pro that can support the gpu without having to get too deep into recompiling things?(somewhat pain free install)
(06-05-2021, 02:45 AM)Atton Wrote: I must ask if there a version of debian for the pinebook pro that can support the gpu without having to get too deep into recompiling things?(somewhat pain free install)
I'm running a stock Debian Unstable on mine. Until recently the only non-Debian package I was running was kernel built using xmixahx's script, but nowadays I'm running stock Debian kernel 5.10.0-7 (A.K.A. 5.10.40). No other third-party or manually compiled packages, GPU acceleration seems to work fine, or at least well enough for DE compositor and media player. In fact, the Debian kernel seems to be a bit more stable than the patched 5.8.5 I used to run - according to uptimed my average uptime on 5.10.40 is several times higher than it was on 5.8.5, and I had more reboots due to updates requiring them than due to system freezing. Can't say anything about performance though - it doesn't seem any worse than on 5.8.5, but I haven't really pushed it to say it's any better than 5.8.5 either.
This message was created with 100% recycled electrons
I'll update the scripts eventually! Smile I don't have any stability issues. What are yours?
I worked through the problems with the debian installer. However it would appear mesa is another story.
I see a lot of panfrost-related issues pop up in dmesg when after doing basic things such as resizing windows. So yes, it's enabled by default but I doubt it works well.
(running Debian11 with sysvinit, vanilla kernel and lxqt)
I wrote a larger post explaining in more detail just now, but it still needs to be approved. I managed to get GPU support working properly in Debian's 5.10 and 5.14 kernels, by fixing a missing dependency-issue.
Create a file `/etc/modprobe.d/panfrost.conf`:
softdep panfrost pre: governor_simpleondemand
Then run `sudo update-initramfs -u` to make this config file part of the initrd file, i.e. part of early boot.
Without this, `dmesg` shows that it repeatedly tries loading 'panfrost' and failing. I can only get it to load after Xorg and my desktop are loaded. And then I would need to restart the desktop manager to make GLX/acceleration/DRI work. If you do this, you should see Mesa Panfrost support in `glxinfo`.
  Debian on Pinebook Pro u974615 7 992 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,022 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,372 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,027 07-15-2023, 02:58 PM
Last Post: u974615
  Armbian is [edit: no longer] dropping support for Pinebook Pro TRS-80 4 4,119 12-23-2022, 12:01 AM
Last Post: TRS-80
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,272 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,329 12-09-2022, 05:04 AM
Last Post: ndp
  Armbian VPU decoding support coming soon LivingLinux 0 800 11-13-2022, 02:32 PM
Last Post: LivingLinux
  How can I install Debian? ImmyChan 1 2,029 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,892 09-23-2022, 08:37 PM
Last Post: computerc
