3D-Printable Button Pegs for the ROCK64 Aluminium Case
As you may know, the ROCK64 Aluminium case does not allow you to press buttons without the use of some utensil to stick into the hole. After having heard of a different user who superglued some plastic pegs to the buttons of his ROCK64, I became inspired to make my own version, which is glueless and just has the plastic pegs sit in the holes, held in by a lip that keeps them inside.
[Image: ROCK64%20Aluminum%20Casing%20Plastic%20P...Photo.jpeg]
The pegs are 3D printed from PLA using a 0.25mm nozzle on a Prusa i3 MK3, though larger nozzles and other printers should work as well. You can download the STL and STEP files from the wiki here: Download .zip
[Image: button_peg_cad.png]
Installation is simple, to quote from the wiki:
Quote:To use the pegs, open your case and remove the ROCK64 from within. Be sure to pull out the light guide and rubber plug to remove it, or else it will catch on them. Once it is removed, turn your bottom half of the case such that the holes for PWR and RST are pointing towards the floor, and drop the pegs into the holes from inside the case, so that the lip prevents them from falling through. Hold them in position with your finger, turn the case the right side up again, and reinstall your ROCK64.
I just wanted to share this on the forums. It was a quick bit of CAD and trial-and-error to get a size that feels right, but I'm quite happy with the result.
Occasional Linux Kernel Contributor, Avid Wiki Updater, Ask Me About Quartz64
Open Hardware Quartz64 Model A TOSLink Adapter
Pi-bus GPIO Extender For ROCKPro64 And Quartz64 Model A
Plebian GNU/Linux
(05-20-2021, 06:54 PM)CounterPillow Wrote: As you may know, the ROCK64 Aluminium case does not allow you to press buttons without the use of some utensil to stick into the hole. After having heard of a different user who superglued some plastic pegs to the buttons of his ROCK64, I became inspired to make my own version, which is glueless and just has the plastic pegs sit in the holes, held in by a lip that keeps them inside.
Thanks on sharing, thumbs up!
  Are HW design files available for ROCK64? irenek 3 4,764 12-11-2023, 09:31 PM
  Rock64 is unreliable after 3 years of service - power problem? ReleaseTheGeese 0 329 11-23-2023, 05:05 AM
Last Post: ReleaseTheGeese
  Rock64 PoE compatbility with Pi4 Hatt recent Single Board Computer offering from PINE kharak 1 1,064 04-26-2023, 11:38 PM
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 0 620 03-21-2023, 03:48 PM
Last Post: o1CRiMSON1o
Brick Rock64 usb2.0 Power Control Floating GPIO Tutorial Files & Notes MarkHaysHarris777 6 13,218 01-15-2023, 10:36 AM
Last Post: ds00
  rock64 totally brick dakobg 2 1,736 11-07-2022, 05:45 PM
Last Post: olivercfc
  Where can I find the ROCK64 POE HAT Zoz 2 2,613 06-08-2022, 12:44 AM
Last Post: Zoz
Smile wooden case for ROCK64 killor 13 16,508 03-04-2022, 06:56 AM
Last Post: killor
  1wire DS18b20 on Rock64? mypineme 6 7,033 09-28-2021, 03:07 PM
Last Post: TRS-80
Information How to Setup Serial Console Cable Over the Rock64 SBC MarkHaysHarris777 9 33,414 09-28-2021, 10:52 AM
Last Post: lewiscamron72
