Unable to get PinePhone Manjaro - Arm to Update
Hey All,
Running Pinephone Manjaro-Arm
I am unable to get my phone out of the box to update.  Going into software it says "no plugin could handle get-updates.  Try to update in terminal, however, shows "error:  failed to update core  (unable to lock database.  This happened with extra and community.  failed to Sync all databases.
(02-24-2021, 05:26 PM)kmk7x Wrote: Hey All,
open terminal program, type sudo pacman -Syyuu
hopefully this works
  PinePhone - boot from microSD laserpyramid 5 307 03-06-2024, 06:37 PM
Last Post: aular
  Are you using the Pinephone as your daily driver? jro 157 105,183 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,526 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 464 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 1,944 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 384 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,481 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,610 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 16,984 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  Pinephone not booting, always vibrating alexander12 7 4,672 11-22-2023, 06:46 PM
Last Post: Scary Guy
