Unusable ROCKPRO64
Hi all,
            after running well for 25 days more or less, my rockpro64 is unusable. All USB ports and ethernet port are not working. I tried with many images, Manjaro, armbian... to top it all sometimes the startup finish with a kernel panic message.
I'm pretty sure that this is a hardware failure. Has anyone a similar experience? I'm very disgusted, the rockpro64 only ran for 25 days more or less. I have had others SBC, like raspberry pi, in the same place for years without problems.
Sad
(02-09-2021, 10:09 AM)drenedo Wrote: Hi all,
Sad
Please make sure that your power supply rated 12V 3A or 5A. Looks like your board not getting enough power. If you are using teh Raspberry Pi power power which is 5V, then for sure is under power.
Sad
The power supply is correct. 12V 5A.
Does it boot at all?
Could you hook up a serial connection like outlined here, and see what the boot init looks like?
https://forum.pine64.org/showthread.php?tid=6387
  Installing Wifi drive for the RockPro64 John45595 0 291 02-10-2024, 11:32 PM
Last Post: John45595
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 743 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 672 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,213 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 879 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,307 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,802 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,631 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 1,006 01-27-2023, 07:43 PM
Last Post: Spater
  RockPro64 and Neon rapier1 2 1,773 10-21-2022, 07:44 AM
Last Post: rapier1
