Very bad video playback
Hi, I switched to manjaro i3 from manjaro XFCE, and I am having really bad video playback everywhere. It is stuttering a lot on 720p, and it is a lot worse than it was on XFCE, basicakky unusable. I tried opening a video with mpv to see if there are any errors and I am getting this:
(+) Video --vid=1 (*) (vp9 3840x1920 29.970fps)
(+) Audio --aid=1 --alang=eng (*) (opus 2ch 48000Hz)
libEGL warning: DRI2: failed to authenticate
[vo/gpu/opengl] Suspected software renderer or indirect context.
[vo/gpu/vulkan/libplacebo] Failed creating instance: VK_ERROR_EXTENSION_NOT_PRESENT
[vo/gpu/vulkan/libplacebo] Failed initializing vulkan instance
[vo/gpu/vulkan/libplacebo] vkEnumeratePhysicalDevices(params->instance, &num, NULL): VK_ERROR_INITIALIZATION_FAILED
[vo/gpu/vulkan/libplacebo] Found no suitable device, giving up.
[vo/gpu/vulkan/libplacebo] Failed initializing vulkan device
Failed to open VDPAU backend libvdpau_nvidia.so: cannot open shared object file: No such file or directory
[vo/vdpau] Error when calling vdp_device_create_x11: 1
[vo/xv] No Xvideo support found.
[vaapi] libva: vaGetDriverNameByIndex() failed with unknown libva error, driver_name = (null)
[vaapi] Failed to initialize VAAPI: unknown libva error
[vo/x11] Warning: this legacy VO has bad performance. Consider fixing your graphics drivers, or not forcing the x11 VO.
AO: [pulse] 48000Hz stereo 2ch float
VO: [x11] 3840x1920 yuv420p
AV: 00:00:02 / 00:10:56 (0%) A-V:  0.460 Dropped: 49
Audio/Video desynchronisation detected! Possible reasons include too slow
hardware, temporary CPU spikes, broken drivers, and broken files. Audio
position will not match to the video (see A-V status field).
AV: 00:00:02 / 00:10:56 (0%) A-V:  0.457 Dropped: 55
You haven't got opengl working.  It should be using the gpu video output.  That plain x11 output driver will be really slow.
Check that the kernel panfrost driver worked:  dmesg | grep panfrost
Then check for opengl support:  glinfo
You should see lines about panfrost that end with initialized panfrost for the kernel. glinfo should have Mesa, Mali, and Panfrost as the first few items it returns.
  Streaming video sites tessa 1 936 01-19-2024, 03:47 AM
Last Post: similarwham
  No Video Out on PBP on all major distros misha64 9 2,563 11-28-2023, 01:41 PM
Last Post: zaius
  Manjaro update broke hardware video acceleration with mpv myself600 2 1,262 01-25-2023, 09:12 AM
Last Post: myself600
Sad 1080p60 video on PBP Linux chewie 2 2,934 08-03-2021, 09:43 AM
Last Post: chewie
Bug 4K@30 video output does not work properly on Pinebook Pro jkm 0 1,554 06-29-2021, 08:43 AM
Last Post: jkm
Lightbulb Hardware video acceleration in Chromium on Manjaro siemsenit 3 4,209 06-01-2021, 09:51 AM
Last Post: siemsenit
  Manjaro w/ Panfrost Drivers vs stock Debian Video Performance decisivedove 15 16,890 03-25-2020, 12:04 AM
Last Post: decisivedove
Question Manjaro XFCE: video outputs (Multi-monitor) EreTIk 2 4,090 03-23-2020, 11:20 AM
Last Post: EreTIk
