Debian kernel stuck at 4.4.167
I am setting up a Rock64 v2 from ayufan's Debian image, while it has been done upgrading from Stretch to Buster, the kernel remains as:
    Linux rock64 4.4.167-1213-rockchip-ayufan-g34ae07687fce #1 SMP Tue Jun 18 20:44:49 UTC 2019 aarch64 GNU/Linux
which is over 1 year old.
How can I manage to upgrade the kernel to a newer version?
Thanks in advance for your kind help.
Personally I just opted for Armbian Buster which includes the latest 5x kernel. You may want to go for Armbian Focal. Either way each Distro is rock solid and pretty much works out of the box with minimal configuration https://www.armbian.com/rock64/
Check your /etc/apt/sources.list
It should have:
deb http://ppa.launchpad.net/ayufan/rock64-ppa/ubuntu bionic main # disabled on upgrade to bionic
deb-src http://ppa.launchpad.net/ayufan/rock64-ppa/ubuntu bionic main
or similar.
Mine were apperently commented out during a dist upgrade and I had to fix it manually.
I just noticed that didn't fix it.
I had to manually add the repositories from http://deb.ayufan.eu/orgs/ayufan-rock64
And even then I didn't quite understand how to automatically install the latest version of linux-image-rockchip-4.4.
I had to install a specific kernel package manuall.
And even then the latest stable release is still over a year old at this poin 4.4.202-1237-rockchip-ayufan.
See also https://forum.pine64.org/showthread.php?tid=12652
(12-28-2020, 08:55 PM)kwinz Wrote: I just noticed that didn't fix it.
Trying to think back . .
Armbian Buster may be the way to go - it looks like this
____            _       __   _  _
|  _ \ ___   ___| | __  / /_ | || |
| |_) / _ \ / __| |/ / | '_ \| || |_
|  _ < (_) | (__|   <  | (_) |__   _|
|_| \_\___/ \___|_|\_\  \___/   |_|
Welcome to Armbian buster with Linux 5.7.15-rockchip64
System load:   0.00 0.00 0.00   Up time:       4 days 11:44
Memory usage:  5 % of 3912MB    IP:            192.168.178.43
CPU temp:      45°C
Usage of /:    8% of 29G
[ General system configuration (beta): armbian-config ]
(12-29-2020, 04:07 AM)S265 Wrote: Trying to think back . .
____            _       __   _  _
Yeah! I see Armbian Buster recommended a lot, I will try it.
Just a general question, sorry if I am a noob:
Is it accurate that Pine only does the hardware and the Kernel is made by the community? Or does Pine employ any kernel hackers writing drivers? Is there an official Kernel?
Are there security backports of any kind?
Does/did "ayufan" (Kamil Trzciński) work for Pine?
How does the Armbian kernel compare with the other Kernels here
https://docs.google.com/spreadsheets/d/1...edit#gid=0
in terms of Suspend to RAM, GPU acceleration, RTC, USB3, ... (see spreadsheet).
I am a bit confused to be honest. Thanks in advance!
  Linux 5.15 Kernel - openSuse mark1250 0 767 12-02-2021, 04:36 PM
Last Post: mark1250
  Security Patches for the Kernel kwinz 9 4,019 10-22-2021, 05:45 AM
Last Post: kwinz
  rock64-debian-mrfixit-190531.img.xz : missing /usr/lib/dri/rockchip_dri.so popi 5 3,390 08-12-2021, 04:55 AM
Last Post: igorp
  Debian build from mrfixit2001 Luke 18 20,965 05-17-2021, 02:35 AM
Last Post: Wizzard
  Debian (Vanilla) on Rock64 and eMMC - how ? as365n4 4 3,754 09-21-2020, 04:33 AM
Last Post: as365n4
  Arch Linux Arm --> Kernel 5.8 breaks installation as365n4 12 8,899 08-31-2020, 01:41 AM
Last Post: as365n4
  pcsx rearmed on rock64 debian stretch does not go fullscreen RockyBoulder 2 3,265 05-09-2020, 03:15 AM
Last Post: lawrencejd
  mainline kernel sound support Openwrt lucize 2 3,025 05-01-2020, 05:09 PM
Last Post: PakoSt
  5.3 kernel support? csrf 5 5,269 04-18-2020, 11:34 PM
Last Post: CameronNemo
  Help troubleshooting kernel panic gabrielfin 3 3,477 03-02-2020, 04:18 PM
Last Post: gabrielfin
