Mobian for x86_64
Hi.
I would like to ask if it is possible to have x86_64 builds of Mobian.
I have a gpd win 2 with a 6inch touch screen and would be nice to have phosh on it, there is also multiple x86_64 tablets out there that will benefit from it too.
Regards!
(10-13-2020, 03:22 AM)paju1986 Wrote: I would like to ask if it is possible to have x86_64 builds of Mobian.
Technically, it's already possible yes, as long as you build the image yourself: get the debos recipes and build using "./build.sh -t amd64"
On the GPD, as it's more or less a standard PC with well-supported hardware (from what I know), I'd rather suggest you install Debian (testing) on it, and then enable Mobian repos using "extrepo enable mobian" (you'll have to apt install extrepo first, of course). Then, package mobian-phosh should bring in everything you need to run phosh on your device Smile
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 1,517 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 70 03-18-2024, 08:54 PM
Last Post: penguins_rule
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,719 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,690 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 581 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 6,543 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,799 07-09-2023, 01:37 AM
Last Post: vusra
  Using Nativefier on PP64 with Mobian paulcarton 0 577 07-05-2023, 03:57 AM
Last Post: paulcarton
  Has anyone got briar-desktop running on mobian? vusra 5 2,863 06-19-2023, 03:02 PM
Last Post: vusra
  Axolotl on PinePhone / Mobian arno_nuehm 219 160,453 03-26-2023, 01:49 AM
Last Post: shulamy
