RockPro64 SSD Expansion Board/SATA Shield
I know these exist for RPi4 but is there a dual SSD expansion board for the RP64 with SATA shield to mount the board to?
(08-19-2020, 10:09 AM)as0zial Wrote: I know these exist for RPi4 but is there a dual SSD expansion board for the RP64 with SATA shield to mount the board to?
https://store.pine64.org/product/rockpro...face-card/
No. More like this: https://cdn.shopify.com/s/files/1/0068/8...1556280944
No, the dual SATA solution available involves a PCIE x4 board and a case designed to fit the SBC, board, fan, heatsink and disks.
https://store.pine64.org/product/rockpro...as-casing/
there are also people on this forum who have gotten PCIE SATA board supporting 5+ drives to work with the RockPro64. So there are some pretty interesting options around. I did take a look at SupTronics and saw they had some fun looking toys as well - I will likely eventually get something Rpi so run alongside my PINE64 stuff, so I will try to keep them in mind.
the link I saw about someone using a 5-port (not sure if chipset could support more but there is a 5-port that works): https://forum.pine64.org/showthread.php?...5#pid73855
it doesn't get happy
it doesn't get sad
it just runs programs
Technically, you could use the board as0zial showed a picture from as it connects through a USB connector, that would also work with the RockPro64.
However, a standard PCIe SATA card is cheaper as there are literally hundreds around on Amazon, Ebay & co. Most of them work thanks to the drivers in the Linux Kernel out of the box, especially the Marvell chipsets are pretty well supported. It just makes sense to look up the chipset that sits on the card and compare that with the card's specification, that solves most problems before even buying (I have seen some cards with 6-8 Ports claiming a chipset that can only handle 4 Ports and then using the SATA splitters, which is just a mess)
Here's the board I'm using for 4 SATA. Seems to be recognized by the hardware and Kernel.
IBM H1110 SAS-2 6Gbps HBA LSI 9211-4i
https://www.ebay.com/itm/IBM-H1110-SAS-2...2749.l2649
  Installing Wifi drive for the RockPro64 John45595 0 173 02-10-2024, 11:32 PM
Last Post: John45595
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 116,501 09-25-2023, 12:46 AM
Last Post: ChriChri
Wink You don't sell case and fan for "ROCKPro64 4GB Single Board Computer"? Clea 1 673 09-17-2023, 12:00 AM
  Want to check maximum toggle speed in Rockpro64 board. kundanjha 0 627 08-14-2023, 07:55 AM
Last Post: kundanjha
  Unable to boot Armbian on new RockPro64 mooseball 5 4,084 07-14-2023, 08:59 AM
Last Post: rockjonn
  Hardware fix for software sound problem on Rockpro64 Ricks Rockpro 0 835 04-06-2023, 03:59 PM
Last Post: Ricks Rockpro
  No sound on Rockpro64 with OpenWrt Patrice 1 1,240 04-06-2023, 02:46 PM
  Cant get rockpro64 working brasilikum 3 1,702 03-19-2023, 06:22 AM
Last Post: runyor
  RockPro64 Stopped working WarpLover 5 2,515 02-06-2023, 10:10 AM
Last Post: diizzy
Lightbulb ROCKPro64 + SSD case model for 3D print Spater 0 957 01-27-2023, 07:43 PM
Last Post: Spater
