WIFi hotspot
I am not sure when this stated working.
I checked yesterday and the menu entry was enabled, so I gave it a try.
It worked flawlessly. I connected three debian devices and did apt-get upgrades. Not once the connection was dropped and speed was around 1Mb/s. With my previous android based phone this was a nightmare: connections were dropped randomly, download speed was sluggish.
Again thank you for making this real.
For me the gotcha was having to disable bluetooth to get the menu entry working. It's a bit confusing because there's no warning or indicator to tell you this is the case, but once I figured that out it has been working perfectly for the last week or so.
(07-08-2020, 07:02 AM)Djhg2000 Wrote: For me the gotcha was having to disable bluetooth to get the menu entry working. It's a bit confusing because there's no warning or indicator to tell you this is the case, but once I figured that out it has been working perfectly for the last week or so.
Ok, thanks. It could be. I think bluetooth was disabled on my PP to save battery time, but I didn't bother to check, if it was really so, or only a UI toggle button with no function at all.
  reset wifi hardware/driver when it dies through console on pp? tuxcall 4 1,777 07-18-2023, 08:54 AM
Last Post: junelung
  How to enable ipv6 for hotspot robgadget 1 719 04-28-2023, 06:59 AM
Last Post: wibble
  Wifi doesn't work after update nickolas 2 1,138 04-14-2023, 10:07 AM
Last Post: nickolas
  Recent install, no wifi user641 3 1,377 01-12-2023, 03:06 PM
Last Post: user641
  Wifi issue since last update and held back updates goku499 11 5,003 09-21-2022, 02:39 PM
Last Post: Katsujinken
  Hotspot and IPv6 gosh000 1 997 06-08-2022, 02:12 AM
Last Post: wibble
  Problem with wifi kubussz 0 838 04-02-2022, 12:57 PM
Last Post: kubussz
  Scripting Bluetooth Hotspot for Mobian biketool 1 1,466 03-20-2022, 03:03 PM
  wifi adapter not found.. why? b7l3wui26r 3 2,072 11-29-2021, 10:28 AM
Last Post: beta-user
  Mobian 'HotSpot" bcnaz 8 5,638 09-30-2021, 11:24 AM
Last Post: TRS-80
