Camera use on Mobian/Brave Heart
Mobian Nightly Release  20200707
Camera is WORKING on the "out of the Box" software,  pictures are not high resolution, but not bad.
Is there a GUI method to add these pictures to my outgoing SMS text messages ?
I did accidentally put a picture of my son,  as my sisters text avatar icon.   Blush
  Thanks,  BC
Chatty doesn't support MMS for now, so that's not possible, no.
(07-08-2020, 02:08 AM)a-wai Wrote: Chatty doesn't support MMS for now, so that's not possible, no.
So texting the Pine phone pictures is not possible ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
No, using email/matrix/telegram/whatever will work, but texting won't (for now)
You are able to receive a picture mms, but it is by far not a nice and easy thing to keep consistent (I have only been able to do it once).
When I have a picture sent to me, the phone receives an sms message with a long string of charecters (these plug up the modem if not cleared and stop sms from functioning). They are visible through mmcli or modem-manager-gui. Using this string you can fabricate a curl command to download the mms file from mmsc server using the proxy and mmsc settings and the "download code" sent to you via sms (this only works through the mobile data from my poking around). Then the mms file needs to be opened / extracted (which is the part that only worked once and I cannot remember how). After poking around for a few hours and not getting farther than opening one message seemingly accidentally; I have not tried sending...
I took a pic of my dog and sent it via email to my GF. Smile
Worked fine, but I had to use Firefox to access my email, as Geary does not want to write emails just yet.
(07-08-2020, 05:36 AM)a-wai Wrote: No, using email/matrix/telegram/whatever will work, but texting won't (for now)
Not a problem,   but helpful to know.
Though I do look forward to it working someday.
Thank you very much for how well so much of the Mobian system does work now.
and Thanks for answering my questions.
Bill
  Mobian repository status henrythemouse 16 8,748 04-10-2024, 10:02 AM
Last Post: diederik
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 15 2,005 03-25-2024, 09:07 AM
Last Post: anonymous
  cant verify mobian image at website gnugpg penguins_rule 0 132 03-18-2024, 08:54 PM
Last Post: penguins_rule
  The program doesn`t detect the camera blag0rag 2 322 02-15-2024, 08:03 PM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 1,995 11-22-2023, 11:46 AM
Last Post: aLoop100o
  What actions needed to keep on mobian testing user641 3 1,823 09-05-2023, 06:44 AM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 633 09-01-2023, 11:29 AM
Last Post: Mahgue
  GStreamer Camera Issue (Unsupported pixformat: 0x56595559 with mbus code: 0x3001) sog8b 1 1,202 07-17-2023, 01:49 AM
Last Post: junelung
  how to update mobian over tor vusra 13 6,899 07-09-2023, 08:57 PM
Last Post: vusra
  opensnitch outbound firewall now works on mobian vusra 2 1,900 07-09-2023, 01:37 AM
Last Post: vusra
