2020
I tried the Mobian 20200615 image on my pinephone CE and it's very impressive - I was able to use calls, texts and data immediately after booting. There are a bunch of features that I like a lot more than UT - including the UI (phosh), the update system being more alike standard debian, and for me, it's been generally more stable than UT at the moment.
I have a couple of questions though:
- Since a recent UT update (I believe now including the Crust firmware), battery life under UT has extended by about 4 hours over Mobian (from about 7 hours to about 11 hours for me). It looks like there are a couple of commits that reference Crust - so I was wondering if it is something that can be enabled currently? Or is it something that still needs more work?
- Is there a way to change between booting from MMC and booting from SD card without removing the card? Using the Mobian image also prevents the volume up + power key combination. I have an sd card writer now, but when I didn't I used the phone to flash to the SD card - unfortunately once the sd card is bootable it prevents this option.
Thanks for all the great work so far - I am hoping to become involved in some capacity with the project eventually - but for now I am just learning.
(06-20-2020, 08:03 PM)scott_VYuCAbn3k1NFK Wrote: - Is there a way to change between booting from MMC and booting from SD card without removing the card? Using the Mobian image also prevents the volume up + power key combination. I have an sd card writer now, but when I didn't I used the phone to flash to the SD card - unfortunately once the sd card is bootable it prevents this option.
That might be possible with PineLoader or possibly Megi's BootUI.
This interests me too
I just saw a 3rd bootloader (untested by me) , but there's a video floating around
https://megous.com/git/p-boot/about/
https://www.youtube.com/watch?v=_2KNkXy66RY
I currently have a 32GB Sandisk Ultra , waiting for a 64GB Sandisk Extreme.
I suppose that the "OS Slices should be min. 16GB" making room for either 2 (32) or 4 (64)
I'm have a CE UBport - But i use Linux Mint (Mate) for desktops (switched from Ubuntu 10.4 when Unity was forced on us) , and Deb 10 for servers.
I'd really like to "Come home", at some time.
And would like a non "Appstore" based distrib , as i feel it might end up limiting my "freedom of choice" ... aka. like the current 2 big phone os'es .
apt-get is fully sufficient for me.
If it can "emulate Desktop" for some X11 Desktop based programs, i have my "Golden Phone OS"
/Bingo
(06-20-2020, 08:03 PM)scott_VYuCAbn3k1NFK Wrote: - Since a recent UT update (I believe now including the Crust firmware), battery life under UT has extended by about 4 hours over Mobian (from about 7 hours to about 11 hours for me). It looks like there are a couple of commits that reference Crust - so I was wondering if it is something that can be enabled currently?
Yup - In Settings, Power at the bottom enable Automatic Suspend when on Battery Power. {note there seems to be a bit of a regression in the current kernel that mobile data does not always recover when you wake the phone up - this is common across all distros AFAIK}
Thanks for the responses (and sorry for forgetting to set a title).
I will try the boot loaders when I get a chance.
I did discover the automatic suspend setting, and it does improve the battery life significantly.
  2020-11-13 Image status. Gribouille 45 35,908 11-14-2021, 12:44 AM
Last Post: Gribouille
  Status update 2020-12-15 a-wai 33 36,144 01-13-2021, 07:14 AM
Last Post: scott_VYuCAbn3k1NFK
  My Daily QA - 2020-10-06 AmazingNutria 6 7,050 01-05-2021, 10:08 PM
Last Post: daniel
  Why the 12/15/2020 build is no where near a daily driver yet TheLastDon 24 19,779 12-31-2020, 09:51 AM
Last Post: HLing
  Status update 2020-11-15 a-wai 17 16,727 12-05-2020, 05:58 PM
Last Post: bcnaz
  Status update 2020-09-05 a-wai 26 28,726 10-12-2020, 01:50 PM
Last Post: dukla2000
  Status update 2020-10-05 a-wai 8 8,802 10-08-2020, 03:20 AM
  My Daily QA - 2020-09-22 AmazingNutria 4 5,091 09-25-2020, 08:33 AM
Last Post: bcnaz
  My Daily QA - 2020-09-11 AmazingNutria 2 3,466 09-20-2020, 09:17 PM
Last Post: daniel
  My Daily QA - 2020-09-10 AmazingNutria 1 2,906 09-11-2020, 08:30 AM
Last Post: daniel
