brand new manjaro PBP - pacman PGP import failure
Just unboxed my new PBP, and i cannot get snapd (or any software) installed. First, generally speaking, is there a forum post for new versions of manjaro, recently shipped? Would love some kind of "getting started" doc...
`5.6.0-2-MANJARO-ARM`
when i run `sudo pacman -S snapd` it attempts to download a PGP key, and fails every time. Computer has network connectivity, can surf the web with firefox.
i've tried the following command in every possible order:
`sudo rm -r /etc/pacman.d/gnupg/`
`sudo pacman-key --init`
`sudo pacman -Syyu`
`sudo pacman-mirrors -g`
`sudo pacman -Sy gnunpg archlinux-keyring manjaro-keyring`
polkit is active and running.
any information at all would be helpful. can't even install vim right now, and can't get any of the boot images from the wiki to work on my SD..
  New User use PineBookPro default OS Manjaro clessard 0 1,581 07-02-2022, 09:01 AM
Last Post: clessard
  Invalid package error in Manjaro-ARM? Easy fix 98cwitr 0 1,594 05-23-2022, 08:49 AM
Last Post: 98cwitr
  Discover vs pacman? dgiffin 2 3,575 01-09-2022, 08:09 AM
Last Post: dgiffin
  Java on Manjaro ARM Pinebook Pro gulagpyromaniac 3 3,858 05-25-2021, 11:05 AM
  No WIFI network discovery in any manjaro installation (but works on fedora) pineitup 1 2,890 02-02-2021, 12:13 AM
Last Post: PineSupporter
  Email addresses in Claws for Manjaro-Arm James Good 6 6,914 08-30-2020, 07:52 PM
Last Post: bcnaz
  Brand Newbie Spaker 1 2,881 05-24-2016, 09:51 AM
Last Post: Luke
