No EDID data for built in screen, PHY missing?
I'm running my Pinebook Pro with Manjaro ARM v20.04 (testing) and the GNOME desktop. I'm delighted to say that Gnome works beautifully except that it is unable to load a color profile and the 'Night Light' feature does not actually change the screen's white balance.
I think these two issues are linked. Loading a color profile relies on the colord daemon. In the journal, I see many instances of the following message from colord:
colord[1613]: failed to get edid data: EDID length is too small
I also see these messages, and I suspect they are related to Gnome's Night Light:
gsd-color[1446]: failed to get edid: unable to get EDID for output
gsd-color[1446]: unable to get EDID for xrandr-eDP-1: unable to get EDID for output
Indeed, checking
/sys/devices/platform/display-subsystem/drm/card0/card0-eDP-1/edid
shows it is empty.
I also see this message in the journal as the kernel initializes:
kernel: rockchip-dp ff970000.edp: no DP phy configured
I'm wondering if this means the current 5.6.0-2 kernel is unable to access the EDID data for the built in panel or (worse) whether the hardware to do this is missing. Can anyone from Pine confirm whether or not the PBP's built in screen is able to provide EDID data or not?
One last thing, I've tried connecting an external monitor via DP and in this case, I do see data in
/sys/devices/platform/display-subsystem/drm/card0/card0-DP-1/edid
  Attempting to install Void Linux, boots into a black screen 9a3eedi 0 312 02-18-2024, 08:54 AM
Last Post: 9a3eedi
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 3,977 07-15-2023, 02:58 PM
Last Post: u974615
  Kali Linux for Pinebook Pro - stuck on the login screen owaspfap 0 648 07-13-2023, 05:21 PM
Last Post: owaspfap
  Blank screen after Armbian 20.04 install to emmc? psychoacoustic 3 3,440 04-01-2023, 03:22 PM
Last Post: TRS-80
  Missing A Few Programs on PostmarketOS on PB Pro publiclewdness 0 541 03-06-2023, 11:33 PM
Last Post: publiclewdness
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 532 02-16-2023, 10:58 AM
Last Post: cowsay
  Archlinux - missing firmware for wifi adapter RudderDuck 9 4,564 11-07-2022, 04:56 PM
Last Post: wgahnagl
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,859 09-23-2022, 08:37 PM
Last Post: computerc
  How do I change screen brightness in Dietpi computerc 2 1,583 07-15-2022, 07:59 PM
  Solution for issue with 'panfrost' module not initializing due to missing dependency cobratbq 0 1,567 12-02-2021, 05:26 PM
Last Post: cobratbq
