PINE64
SSH over USB - Printable Version
+--- Forum: PinePhone Software (https://forum.pine64.org/forumdisplay.php?fid=121)
+---- Forum: Mobian on PinePhone (https://forum.pine64.org/forumdisplay.php?fid=139)
+---- Thread: SSH over USB (/showthread.php?tid=12408)
Pages: 1 2
RE: SSH over USB - 3x5co - 12-22-2021
Am I the only one who can no longer SSH over USB?
RE: SSH over USB - 3x5co - 10-21-2022
I have an update here, in case anyone else is having this problem. Thanks to @dukla2000 for the idea to run `nmtui`.
What I did is run `sudo nmtui`, then edit the USB connection, and for the IPv4 connection, set it to 'Shared'. Then I went back to the main nmtui screen, then to 'Activat a connection', select USB, and then selevt 'Activate'.
This will not work if the IPv4 connection is set to 'Automatic'. If I try to activate the connection nmtui will say 'connection not available on device usb0 because device has no carrier'.
If I exit out of nmtui, and run ip addr show usb0, now I'll see:
usb0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc pfifo_fast state DOWN group default qlen 1000
link/ether 42:70:fe:6c:09:71 brd ff:ff:ff:ff:ff:ff
inet 10.66.0.1/24 brd 10.66.0.255 scope global noprefixroute usb0
valid_lft forever preferred_lft forever
inet6 fe80::f137:ad8:84ea:8aef/64 scope link tentative noprefixroute
If I'm already SSHed into the phone, I can run ssh mobian@10.66.0.1 and ssh back into myself on that IP. however, I can't ssh to 10.66.0.1 from my computer. I can't even ping it.
I should also point out that if I have the wifi off on my phone and I try to ssh to it over lan, it'll say 'no route to host'. But when I connect my phone to the computer with USB, and then try to connect, it just hangs at the CLI and does nothing. Not sure if that's relevant.
RE: SSH over USB - 3x5co - 10-24-2022
Apparently, other people are indeed having this problem: https://gitlab.com/mobian1/devices/sunxi64-linux/-/issues/11
I cleaned out my USB port, which was pretty gunky, but this didn't solve anything. When I run lsusb, it's clear that my computer doesn't see the connection to the phone, at all. This is regardless of which cable I use, and even if I switch computers. So that seems to be the actual problem.
I have installed umtp-responder, mobian-devtools (I saw a lot of references to pinephone-devtools, but apparently this package doesn't exist anymore), but none of this is relevant if the computer can't see the phone at all.
RE: SSH over USB - Frexit - 10-24-2022
(10-24-2022, 08:03 AM)3x5co Wrote: Apparently, other people are indeed having this problem: https://gitlab.com/mobian1/devices/sunxi64-linux/-/issues/11
Got the same problem with an external non Piphone USB cable, until i just changed it...
Huh. Well my Pinephone came with a long, red cable and that's the one I use. Now I'm using a different cable that I normally use to connect to a UbPorts Google Pixel. The Pixel connects fine with either cable and the pinephone connects with neither.
